Enables MPLS on the switch.
Disabled.
Enabling MPLS allows MPLS processing to begin for any enabled MPLS protocols (RSVP-TE and/or LDP).
While MPLS is transitioning to the enabled state, only the MPLS show commands are accepted.
When MPLS is enabled on a stack, you can only add MPLS-compatible switches to the stack.The following command globally enables MPLS on the switch:
enable mpls
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.2.1 Licensing Guide document.
