Displays IGMP snooping registration information for all VLANs.
| detail | Displays the information in detailed format. |
| IGMPv3 | Displays the IGMP group in IGMPv3 format (if group record is IGMPv3 compatible, otherwise displays in earlier format). |
IGMPv2.
None.
The following command displays IGMP snooping registration information for all VLANs:
# show igmp snooping Igmp Snooping Flag : forward-all-router Igmp Snooping Flood-list : none Igmp Snooping Proxy : Disable Igmp Snooping Filters : per-port Vlan Vid Port #Senders #Receivers Router Enable -------------------------------------------------------------- Default 1 0 Yes v1 4090 0 Yes
The IGMP Forwding Lookup mode output was removed from this command in ExtremeXOS 15.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IGMP snooping feature, see the Switch Engine v33.2.1 Licensing Guide document.
