show bgp evpn mac
show bgp evpn mac {mac-address mac_address}
Description
Shows the current set of MAC addresses configured in EVPN.
Syntax Description
bgp Specifies BGP.
evpn Specifies Ethernet VPN (RFC 7432).
mac Shows only the MAC entries from the EVPN MAC/IP table.
mac-address Specifies restricting the display to a particular MAC address.
mac_address Selects the MAC address to show.
Default
N/A.
Usage Guidelines
If the ESI and ESI-Port fields are non-zero, then the entry was learned over a shared interface. The remote LACP partner‘s 6-byte MAC address is part of the ESI. For a full decoding of the ESI, see RFC 7432. The (S)source column indicates whether the entry was learned (L)ocally or (R)emotely. The local entries are from the MAC forwarding database. The remote entries are in the MAC forwarding database only if the “In Use” flag is set to yes.
The following example shows the current set of MAC addresses configured in EVPN.
# show bgp evpn mac
Src EVI-Idx MAC               BGP Next Hop           VNI ESI                            ESI-Port   In Use
L       190 00:04:96:9d:64:e2                      10000 00:01:02:03:04:05:06:07:08:09  22         Yes
R       190 00:04:96:9d:66:e8 3.3.3.103            10000                                           Yes
R      1020 00:04:96:9c:2c:a2 1.1.1.101           101020                                           Yes
L      1020 00:04:96:9d:64:e2                     101020                                           Yes
R      1020 00:04:96:9d:66:e8 3.3.3.103           101020                                           Yes
R      1020 01:01:01:01:01:01 3.3.3.103           101020                                           Yes
L      3500 00:04:96:9d:64:e2                     111103                                           Yes
R      4089 00:04:96:9c:2c:a2 1.1.1.101           101021                                           Yes
L      4089 00:04:96:9d:64:e2                     101021                                           Yes
R      4089 00:04:96:9d:66:e8 3.3.3.103           101021                                           Yes
R      4089 00:0f:20:98:87:5a 3.3.3.103           101021                                           Yes
Src: (L) Local, (R) Remote
In Use: Yes/No - Indicates if entry is installed in MAC forwarding database.
Total MAC/IP entries: 11
This command was first available in ExtremeXOS 30.2.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.2.1 Licensing Guide document.
