disable igmp ssm-map
disable igmp ssm-map {vr vr-name}
Description
Disables IGMP SSM mapping.
Syntax Description
vr-name Specifies a virtual router name. If the VR name is omitted, the switch disables mapping on the VR specified by the current CLI VR context.
Default
Disabled on all interfaces.
Usage Guidelines
None.
The following command disables IGMP-SSM mapping on the VR in the current CLI VR context:
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.2.1 Licensing Guide document.
