This command resets most configurable parameters for the specified router process to the default values.
| area_name | Specifies the router process to be unconfigured. |
| level [1|2] | Specifies either level 1 or level 2. |
N/A.
This command does not delete interfaces from the router process, but it does disable them. The system ID and IS type are not changed. Where appropriate, the default values apply to level 1, level 2, and both IPv4 and IPv6.
The following command resets the area configuration parameters for areax:
unconfigure isis area areax
This command is available on platforms with a Premier license as described in the Switch Engine 33.1.1 Feature License Requirements document.
