show netlogin
show netlogin {port port_list [ {vlan} vlan_name | vlan vlan_list]} {dot1x {detail}} {mac} {web-based}
Description
Shows status information for network login.
Syntax Description
port_list Specifies one or more ports or slots and ports.
vlan_name Specifies the name of a VLAN.
vlan_listSpecifies a VLAN list of IDs.
dot1x Specifies 802.1X information.
detail Shows detailed information.
mac Specifies MAC-based information.
web-based Specifies web-based information.
Default
N/A.
Usage Guidelines
Depending on your configuration, software version, and the parameters you choose to display, the information reported by this command may include some or all of the following:
  • Whether network login is enabled or disabled.
  • The base-URL.
  • The default redirect page.
  • The logout privileges setting.
  • The network login session-refresh setting and time.
  • The MAC and IP address of supplicants.
  • The type of authentication, 802.1X, MAC-based, or HTTP (web-based).
  • The guest VLAN configurations, if applicable.
  • The dynamic VLAN state and uplink ports, if configured.
  • Whether network login port restart is enabled or disabled.
  • Which order of authentication protocols is currently being used.
If you do not specify the authentication method, the switch displays information for all network login authentication methods.
The "current user" count displays how many resources are left to be able to be configured/authenticated. Admin-profile rules consume a resource similar to authenticated users, even if that particular MAC address is not presently on the system (a static admin-profile port rule also increments this count). As a result, the "current user" count value reflects a combination of users and consumed resources (admin-profile rules).
The following sample output shows the summary network login information:
# show netlogin
NetLogin Authentication Mode : web-based ENABLED;  802.1X ENABLED;  mac-based ENABLED
NetLogin VLAN                : "nvlan"
NetLogin move-fail-action    : Authenticate
NetLogin Client Aging Time   : 5 minutes
Dynamic VLAN Creation        : Enabled
Dynamic VLAN Uplink Ports    : 12
Web-based Mode Global Configuration
Base-URL                 : network-access.com
Default-Redirect-Page    : http://www.yahoo.com
Logout-privilege         : YES
Netlogin Session-Refresh : ENABLED; 3 minutes
Authentication Database  : Radius, Local-User database
802.1X Mode Global Configuration
Quiet Period                    : 60
Supplicant Response Timeout     : 30
Re-authentication period        : 200
RADIUS server timeout           : 30
EAPOL MPDU version to transmit  : v1
MAC Mode Global Configuration
Re-authentication period        : 0 (Re-authentication disabled)
Authentication Delay Period     : 0 (Default)
MAC Address/Mask      Password (encrypted)            Port(s)
00:00:86:3F:1C:35/48  yaqu                            any
00:01:20:00:00:00/24  yaqu                            any
00:04:0D:28:45:CA/48  =4253C5;50O@                    any
00:10:14:00:00:00/24  yaqu                            any
00:10:A4:A9:11:3B/48  yaqu                            any
00:10:A4:00:00:00/24  yaqu                            any
Default               yaqu                            any
Port: 5,  Vlan: nvlan,  State: Enabled,  Authentication: mac-based,  Guest Vlan <Not Configured>: Disabled
MAC                IP address       Authenticated  Type    ReAuth-Timer   User
Port: 9,  Vlan: nvlan,  State: Enabled,  Authentication: web-based,  Guest Vlan <Not Configured>: Disabled
Port: 10,  Vlan: nvlan,  State: Enabled,  Authentication: 802.1X, mac-based,  Guest Vlan <Not Configured>: Disabled
Port: 17,  Vlan: engr,  State: Enabled,  Authentication: mac-based,  Guest Vlan <Not Configured>: Disabled
Port: 17,  Vlan: mktg,  State: Enabled,  Authentication: mac-based,  Guest Vlan <Not Configured>: Disabled
Port: 19,  Vlan: corp,  State: Enabled,  Authentication: 802.1X,  Guest Vlan <Not Configured>: Disabled
00:04:0d:50:e1:3a  0.0.0.0          No                     0              00040D50E13A
00:10:dc:98:54:00  10.201.31.113    Yes, Radius    802.1X  24             md5isp7
Port: 19,  Vlan: nvlan,  State: Enabled,  Authentication: 802.1X,  Guest Vlan <Not Configured>: Disabled
00:04:0d:50:e1:3a  0.0.0.0          No             802.1X  0
Port: 19,  Vlan: voice-ip,  State: Enabled,  Authentication: 802.1X,  Guest Vlan <Not Configured>: Disabled
00:04:0d:50:e1:3a  0.0.0.0          Yes, Radius    802.1X  75             00040D50E13A
The following command shows more detailed information, including the configured authentication methods:
# show netlogin port 3:2 vlan "Default"
Port: 2:1       Vlan: Default
Authentication: Web-Based, 802.1X
Port State:     Unauthenticated
Guest VLAN:     Not Enabled
DHCP:           Not Enabled
MAC                IP address      Auth   Type      ReAuth-Timer User
00:0C:F1:E8:4E:13  0.0.0.0         No     802.1X    0            Unknown
00:01:30:F3:EA:A0  10.0.0.1        Yes    802.1X    0            testUser
The following command shows information about a specific port configured for network login:
# show netlogin port 1:1
Port          : 1:1
Port Restart  : Enabled
Vlan          : Default
Port State    : Enabled
Guest Vlan    : Disabled
The following command shows information for 802.1X mode:
# show netlogin dot1x
NetLogin Authentication Mode : web-based DISABLED;  802.1x ENABLED;  MAC-based ENABLED
NetLogin VLAN                : "nlvlan"
NetLogin move-fail-action    : Deny
Dynamic VLAN Creation        : Disabled
Dynamic VLAN Uplink Ports    : None
Authentication Protocol Order: 802.1x, web-based, mac-based (default)
Maximum Number Of Users      : 256 (Policy Enabled only)
        802.1x Mode Global Configuration
Tag EAPOL on tagged ports       : Off
RADIUS Accounting               : On
Port: 1,  Vlan: nlvlan,  State: Enabled,  Authentication: 802.1x, mac-based
Authentication Failure Vlan <Not Configured>: Disabled
Authentication Service-Unavailable Vlan <Not Configured>: Disabled
        802.1x Port Configuration
Quiet Period                  : 60
Re-authentication             : On
Re-authentication period      : 1200
Max Re-authentications        : 3
Guest Vlan <Not Configured>   : Disabled
        MAC Mode Port Configuration
Re-authentication             : Off
Re-authentication period      : 3600
Authentication Delay          : 0 seconds (Default)
        Netlogin Clients
(B) - Client entry Blackholed in FDB
Port: 1,  Vlan: v1,  State: Enabled,  Authentication: 802.1x, mac-based
Quiet Period                  : 60
        Netlogin Clients
00:00:00:00:00:02  0.0.0.0          Yes, Radius       802.1x  658            harish
Number of Clients Authenticated  : 1
For 802.1X, if re-authentication is disabled, the re-authentication period appears as follows:
The show netlogin port 5:4 dot1x command generates the following sample output:
Port						: 5:4
Port Restart						: Disabled
Vlan						: corp
Authentication						: 802.1X
Guest Vlan						: Enabled
MACIP addressAuthenticatedTypeReAuth-TimerUser
00:10:dc:92:53:2d10.201.31.119Yes,Radius802.1X14md5isp4
The show netlogin port 5:4 dot1x detail command generates the following sample output:
Port: 5:4
Port Restart: Disabled
Vlan: corp
Port State: Enabled
Guest Vlan: Enabled
MAC
00:10:dc:92:53:2d   : IP=10.201.31.119   Auth=Yes  User=md5isp4
: AuthPAE state=AUTHENTICATED BackAuth state=IDLE
: ReAuth time left=8       ReAuth count=0
: Quiet time left=0
The following displays keep session on re-authentication unavailable information (lines 11 and 22):
# show netlogin
NetLogin Authentication Mode : web-based DISABLED;  802.1x DISABLED;  MAC-based DISABLED
NetLogin VLAN                : <Not Configured>
Maximum Number Of Users      : 768 (Policy Enabled only)
Keep Session On Reauth Service Unavailable: Off
Default-Redirect-Page    : ENABLED; http://www.extremenetworks.com
Netlogin Session-Refresh : ENABLED; 3 minute(s) 0 second(s)
Refresh failures allowed : 0
Reauthenticate on refresh: Disabled
Proxy Ports              : 80(http),443(https)
Re-authentication period	: 0 (disabled)
Authentication Username Format  : None
Authentication Username Case    : Upper
Number of Clients Authenticated  : 0
This command was first available in ExtremeXOS 11.1.
Information about the guest VLAN was added in ExtremeXOS 11.2.
Information about the configured port MAC list was added in ExtremeXOS 11.3.
Information about dynamic VLANs and network login port restart was added in ExtremeXOS 11.6.
The vlan_list variable was added in ExtremeXOS 16.1.
Information about authentication delay added in ExtremeXOS 21.1.
Authentication username format information was added in ExtremeXOS 22.3.
Platform Availability
