enable log target
enable log target [console | memory-buffer | nvram | primary-node|backup-node| session | syslog [all | ipaddress udp-port {udp_port} | ipPort | ipaddress tls_port {tls_port}] {vr vr_name} {local0...local7}]]
Description
Starts sending log messages to the specified target.
Syntax Description
console Specifies the console display.
memory-buffer Specifies the switch memory buffer.
nvram Specifies the switch NVRAM.
primary-node Specifies the primary node of a stack.
backup-node Specifies the backup node of a stack.
session Specifies the current session (including console display).
syslog Specifies a syslog target.
all Specifies all of the remote syslog servers.
ipaddress Specifies the syslog IP address.
ipPort Specifies the UDP port number for the syslog target.
tls_port Specifies remote Syslog server Transport Layer Security (TLS) for connection type.
tls_port TLS port number.
vr_name Specifies the virtual router that can reach the server IP address.
Note: User-created VRs are supported only on the platforms listed for this feature in the Switch Engine v33.2.1 Licensing Guide document.
local0 ... local7 Specifies the local syslog facility.
Default
Enabled, for memory buffer and NVRAM; all other targets are disabled by default.
Usage Guidelines
This command starts sending messages to the specified target. By default, the memory-buffer, NVRAM, primary node, and backup node targets are enabled. Other targets must be enabled before messages are sent to those targets.
Configuration changes to the session target are in effect only for the duration of the console display or Telnet session, and are not saved in FLASH. Others are saved in FLASH.
You can also use the following command to enable displaying the log on the console: enable log display
This command is equivalent to the enable log target console-display command.
The following example enables log messages on the current session:
enable log target session
The ipPort parameter was first available in ExtremeXOS 11.0.
The udp-port parameter was added in ExtremeXOS 21.1.
Transport Layer Security (TLS) option added in ExtremeXOS 22.1.
Platform Availability
