disable virtual-router
disable virtual-router vrf-name
Description
Disables a VRF.
This command is only applicable for VRFs.
Syntax Description
vrf-name
Specifies the name of the
VRF. |
Usage Guidelines
When you disable a VRF, the software does the following:
- Disables Layer 3 protocols.
- Marks static routes as inactive and removes them from
the hardware forwarding tables.
- Flushes the IP ARP and IPv6 neighbor-discovery
caches.
The following example disables VRF "vrf1":
disable virtual-router vrf1
This command was
first available in ExtremeXOS 12.5.
Platform Availability
