synchronize stacking
synchronize stacking {node-address node_address | slot slot_number}
Description
This command copies certain NVRAM based configuration parameters to the target node.
Syntax Description
node_address Specifies the MAC address of a node in the stack. To view the MAC addresses for all nodes in a stack, enter the show stacking command.
slot_number Specifies the slot number of the target node. To view the slot numbers, enter the show stacking command.
Default
N/A.
Usage Guidelines
This command synchronizes the following NVRAM-based parameters:
  • Stacking mode.
  • Stack MAC address.
  • Failsafe account and password.
  • Failsafe account access point permissions (whether the failsafe account is allowed over the stacking links, console port, or management port).
  • The selected partition.
These parameters are copied from the executing node's NVRAM to the target node's NVRAM.
Example for the synchronize stacking command output:
Slot-2 Stack.3 > synchronize stacking slot 3
Are you sure you want to synchronize the specified slot with this slot's stacking configuration? (y/n) Yes
Synchronized configuration will take effect at the next reboot of the specified node(s).
Slot-2 Stack.4 >
Slot-2 Stack.4 > synchronize stacking node 00:04:96:27:87:10
Are you sure you want to synchronize the specified node with this node's stacking configuration? (y/n) Yes
Slot-2 Stack.5 >
Slot-2 Stack.5 > synchronize stacking
Are you sure you want to synchronize all remote nodes with this node's stacking configuration? (y/n) Yes
Slot-2 Stack.6 >
This command was first available in ExtremeXOS 12.0.
Platform Availability
This command is available with all licenses and platforms that support the SummitStack feature. For information about which licenses and platforms support the SummitStack feature, see the Switch Engine v33.2.1 Licensing Guide document.
