enable mpls static lsp
enable mpls static lsp {lsp_name | all }
Description
Administratively enables one or all static LSPs.
Syntax Description
lsp_name Identifies the LSP to be enabled.
all Specifies that all static LSPs on this LSR are to be enabled.
Default
N/A.
Usage Guidelines
On executing this command, the software tries to activate the static LSP by programming the LSP in hardware. Static LSPs are not enabled by default. You need to explicitly enable LSPs after the ingress and egress segments have been configured.
The following command enables a static LSP:
enable mpls static lsp lsp598
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.2.1 Licensing Guide document.ture-link-in-22.1"/>
