show mld
show mld {vlan} {name}
Description
This command can be used to display an MLD-related configuration and group information, per VLAN or for the switch as a whole.
Syntax Description
name Specifies a VLAN name.
Default
N/A.
Usage Guidelines
If you do not specify a VLAN, the command displays the switch configuration.
The following is sample output from the show mld command:
# show mld
VLAN            IP Address                           Flags  nLRMA  nLeMA MLDver
Default         ::/0                                ---iz-      0      0      0
v1              ::/0                                U--iz-      0      5      0
Flags:   (f) Forwarding Enabled, (g) Fast-learning on, (i) MLD Enabled,
(m) Multicast Forwarding Enabled, (U) Interface Up,
(z) MLD Snooping Enabled.
(nLeMA) Number of Learned Multicast Addresses
(nLRMA) Number of Locally Registered Multicast Addresses
The following command displays the MLD configuration for VLAN v1:
# show mld v1
Query Interval    : 125 sec
Max Response Time : 10 sec
Last Member Query : 1 sec
Robustness        : 2
Interface on VLAN v1 is enabled and up.
inet6 ::/0
Locally registered multicast addresses:
Learned multicast addresses(Last Querier=fe80::204:96ff:fe3a:ce50):
ff02::2                         ff02::1:ff56:5c2b
ff02::1:ff00:2                  ff02::1:ff3a:ce50
ff02::1:ff55:5c27
s = static MLD member
Flags:
IP Fwding  NO     IPmc Fwding  NO             MLD YES
MLD Ver  v0        Snooping YES
Platform Availability
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.2.1 Licensing Guide document.
