show vrrp group
show vrrp group group_name
Description
This command shows VRRP group status.
Syntax Description
group Form a group of VRRP VRs to operate in high-scale mode.
group_name Specifies the VRRP group name.
Default
None.
The following example shows VRRP group information for group "ExtremeNet":
show vrrp group ExtremeNet
Group Name: ExtremeNet        Group Status : Enabled
                      Virtual                  Master
   VLAN Name VRID Pri IP Address        State  MAC Address      TP/TR/TV/P/T     /FR
Primary-VR:
      v1(En) 0001 225 100.0.0.100        MSTR  00:00:5e:00:01:01 0  0  0 Y  1      Y
Secondary-VR(s):
     v10(En) 0001 225 100.10.0.100       MSTR  00:00:5e:00:01:01 0  0  0 N 40      Y
     v11(En) 0001 200 100.11.0.100       MSTR  00:00:5e:00:01:01 0  0  0 N 40      Y
  En-Enabled, Ds-Disabled, Pri-Priority, T-Advert Timer, P-Preempt,
  TP-Tracked Pings, TR-Tracked Routes, TV-Tracked VLANs, FR- Fabric Routing
Total number of member VRs of group : 3
This command was first available in ExtremeXOS 22.2.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.2.1 Licensing Guide document.
