show msdp sa-cache
show msdp [sa-cache | rejected-sa-cache] {group-address grp-addr} {source-address src-addr} {as-number as-num} {originator-rp originator-rp-addr} {local} {peer remoteaddr} {vr vrname}
Description
This command displays the SA cache database. The following quadruplet per SA cache entry displays: {Group, Source, originating RP, and peer}. In addition, information about the following displays: the cache uptime, aging, whether sources are local or remote, etc.
Syntax Description
grp-addr Displays the SA cache within the specified group address range.
src-addr Displays the SA cache within the specified source address range.
as-num Displays all SA cache that originated from the specified Autonomous System (AS) number.
originator-rp-addr Displays all SA cache entries that were originated by the specified rendezvous point.
local Displays locally originated SA cache entries only.
remoteaddr Displays the SA cache entries received from the MSDP peer with the specified IP address.
vrname Specifies the name of the virtual router to which this command applies. If a name is not specified, it is extracted from the current CLI context.
Default
N/A.
Usage Guidelines
Use this command to view and troubleshoot the SA cache database. There are various filtering criteria you can use to display just a subset of the SA cache database. The following are some of the criteria, which you can use together or separately, to display information about the SA cache:
The following command displays the SA cache database:
# show msdp sa-cache
Group Address   Source Address  Originator      Peer Address    Age/Ageout In
235.100.200.1   10.20.30.1      60.0.0.5        10.0.0.1        00:44:24/05:10
235.100.200.2   10.20.30.2      60.0.0.5        192.0.0.16      00:44:24/05:16
235.100.200.3   10.20.30.3      60.0.0.5        10.0.0.1        00:44:24/05:10
235.100.200.4   10.20.30.4      60.0.0.5        10.0.0.1        00:44:24/05:10
235.100.200.5   10.20.30.5      60.0.0.5        55.0.0.5        00:44:24/05:01
235.100.200.6   10.20.30.6      60.0.0.5        178.54.67.23    00:44:24/05:17
235.100.200.7   10.20.30.7      60.0.0.5        112.234.213.12  00:44:24/05:43
235.100.200.8   10.20.30.8      60.0.0.5        10.0.0.1        00:44:24/05:10
235.100.200.9   10.20.30.9      60.0.0.5        10.0.0.1        00:44:24/05:10
235.100.200.10  10.20.30.10     60.0.0.5        0.0.0.0         00:44:24/00:00
235.100.200.11  10.20.30.11     60.0.0.5        0.0.0.0         00:44:24/00:00
235.100.200.12  10.20.30.12     60.0.0.5        0.0.0.0         00:44:24/00:00
235.100.200.13  10.20.30.13     60.0.0.5        0.0.0.0         00:44:24/00:00
235.100.200.14  10.20.30.14     60.0.0.5        0.0.0.0         00:44:24/00:00
235.100.200.15  10.20.30.15     60.0.0.5        0.0.0.0         00:44:24/00:00
235.100.200.16  10.20.30.16     60.0.0.5        0.0.0.0         00:44:24/00:00
235.100.200.17  10.20.30.17     60.0.0.5        0.0.0.0         00:44:24/00:00
235.100.200.18  10.20.30.18     60.0.0.5        0.0.0.0         00:44:24/00:00
235.100.200.19  10.20.30.19     60.0.0.5        0.0.0.0         00:44:25/00:00
Number of accepted SAs      : 255
Number of rejected SAs      : 0
Flags: (a) Accepted, (f) Filtered by policy, (r) RPF check failed
This command was first available in ExtremeXOS 12.0.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the Switch Engine v33.2.1 Licensing Guide document.
