enable vrrp group
enable vrrp group group_name {configuration | members}
Description
This command appliles group configuration on individual VRs and they then become member VRs.
Syntax Description
group Form a group of VRRP VRs to operate in high-scale mode.
group_name Specifies the VRRP group name.
configuration Applies group configuration on individual VRs (default).
members Enables all VRs that are members of the group.
Default
If you do not specify, group configuration is applied to individual VRs.
Usage Guidelines
When this command is issued the primary VR of the group sends VRRP advertisements at configured intervals. Secondary VRs send at a much slower rate.
The following example brings group configuration into effect on the member VRs of the group:
enable vrrp group ExtremeNet configuration
This command was first available in ExtremeXOS 22.2.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.2.1 Licensing Guide document.
