Enables a trial software license that allows you to use advanced features.
| trial |
Specifies to enable the trial license. |
N/A.
When you enable a trial license, the system generates a daily message showing the number of days until expiry.
The following command enables a trial license on the specified switch:
enable license trial
This command was first available in version 33.2.1.
