Configures the local cluster ID.
| cluster-id | Specifies a 4 byte field used by a route reflector to recognize updates from other route reflectors in the same cluster. The range is 0 - 4294967295. |
N/A.
BGP must be disabled before the cluster ID can be changed.
Used when multiple route reflectors are used within the same cluster of clients.
The following command appends a BGP route reflector cluster ID to the cluster list of a route:
configure bgp cluster-id 40000
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.2.1 Licensing Guide document.
