configure snmpv3 delete user
configure snmpv3 delete user [all | [[hex hex_user_name] | user_name] {engine-id engine_id}]
Description
Deletes an existing SNMPv3 user.
Syntax Description
all Specifies that all users are to be deleted.
hex_user_name Specifies the user name to delete. The value is to be supplied as a colon separated string of hex octets.
engine-idSNMP engine ID
engine-idEngine ID in hexadecimal (Default: local engine ID).
Default
N/A.
Usage Guidelines
Use this command to delete an existing user.
Deleting users does not implicitly remove the related group-to-user association from the VACMSecurityToGroupTable. To remove the association, use the following command:
configure snmpv3 delete group {[[hex hex_group_name] | group_name]} user [all-non-defaults | {[[hex hex_user_name] | user_name] {sec-model [snmpv1|snmpv2c|usm]}}]
The following command deletes all users:
configure snmpv3 delete user all
The following command deletes the user "guest":
configure snmpv3 delete user guest
The following command deletes a remote user named "ambiguoususer" with engine id 11:22:33:
configure snmpv3 delete user ambiguoususer engine-id 11:22:33
The hex_user_name parameter was added in ExtremeXOS 11.0.
The engine_id keyword was added in ExtremeXOS 15.4.
The all-non-default keyword was replaced with the all keyword in ExtremeXOS 22.1.
Platform Availability
