disable esrp
disable esrp {esrpDomain}
Description
Disables ESRP for a named domain or for the entire switch.
Syntax Description
esrpDomain Specifies the name of an ESRP domain.
Default
Disabled for the entire switch.
Usage Guidelines
If you do not specify a domain name, ESRP is disabled for the entire switch.
If you disable an ESRP domain, the domain enters the Aware state, the switch notifies its neighbor that the ESRP domain is going down, and the neighbor clears its neighbor table. If the master switch receives this information, it enters the neutral state to prevent a network loop. If the slave switch receives this information, it enters the neutral state.
The following command disables ESRP for the entire switch:
disable esrp
The following command disables ESRP for the domain esrp1:
disable esrp esrp1
This command was first available in ExtremeXOS 11.0.
Platform Availability
This command is available on all platforms that use the Edge, Advanced Edge, or Core license. For information on the licenses available for each platform, see the Switch Engine v33.2.1 Licensing Guide document.
