show vrrp vlan
show vrrp [ {vlan} vlan_name | vlan vlan_list] {stats}
Description
Displays VRRP information for a particular VLAN.
Syntax Description
vlan_name Specifies the VRRP VLAN.
vlan_list Specifies the VRRP VLAN list of IDs.
stats Specifies statistics for a particular VLAN.
Default
N/A.
Usage Guidelines
Depending on the software version running on your switch or your switch model, additional or different VRRP information might be displayed.
If you specify the command without the stats keyword, the following VRRP information appears:
If you specify the stats keyword, you see counter and statistics information for the specified VRRP VLAN.
The following example displays configuration information for the specified VRRP VLAN:
# show vrrp vlan v1
VLAN:  v1       VRID:  1        VRRP:  Disabled State:  INIT
Virtual Router:  VR-Default
Priority:  100(backup)  Advertisement Interval:  1 sec
Version: v2     Preempt:  Yes   Preempt Delay: 0 sec
Authentication:  simple-password  key:  none
Virtual IP Addresses:
Accept mode:  Off
Host-Mobility:  Off
Host-Mobility Exclude-Ports:
Tracking mode:  ALL
Tracked Pings:  -
Tracked IP Routes:  -
Tracked VLANs:  -
Fabric Routing: Off
* indicates a tracking condition has failed
The following example displays statistics for VLAN vrrp-1:
#show vrrp vlan v1 stats
VLAN v1, VR ID 1
  VRID Errors                 : 0   Authentication Type Mismatch   : 0
  Version Errors              : 0   Invalid Authentication Type    : 0
  Checksum Errors             : 0   Authentication Failures        : 0
  TTL Errors                  : 0   Advertisement Interval Errors  : 0
  Packet Length Errors        : 0   Address List Errors            : 0
  Advertisements GotV3 DropV2 : 0
  Advertisements Accepted     : 0   Priority Zero Packets Received : 0
  Become Master               : 0   Priority Zero Packets Sent     : 0
The vlan_list variable was added in ExtremeXOS 16.1.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.2.1 Licensing Guide document.
