disable vrrp group
disable vrrp group group_name {configuration | members}
Description
This command disables group mode on member VRs so that they can operate in individual VR mode.
Syntax Description
group Form a group of VRRP VRs to operate in high-scale mode.
group_name Specifies the VRRP group name.
configuration Removes group configuration on individual VRs (default).
members Disables all VRs that are members of the group.
Default
If you do not specify, group configuration is removed from individual VRs.
The following example disables administratively all member VRs of the group. This may be useful for debugging issues:
disable vrrp group ExtremeNet members
This command was first available in ExtremeXOS 22.2.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.2.1 Licensing Guide document.
