show msdp
show msdp {vr vrname}
Description
This command displays global configuration and run-time parameters for MSDP.
Syntax Description
vrname Specifies the name of the virtual router to which this command applies. If a name is not specified, it is extracted from the current CLI context.
Default
N/A.
Usage Guidelines
Use this command to verify the global configuration parameters of MSDP.
The following command displays global configuration and run-time parameters for MSDP:
Switch.2 # show msdp
MSDP Enabled         : No                  VR-Name              : VR-Default
Originator RP Addr   : not configured      SA Cache ageout time : 360
Store SA Cache       : Yes                 SA Cache Server      : not configured
Export Local SAs     : Yes                 Export SA filter     : not configured
Max Rejected Cache   : not configured      Encapsulate data     : Yes
Num of Rejected SAs  : 0                   Total Num of SAs     : 0
Num of Local SAs     : 0                   AS Disp Format       : Asdot
This command was first available in ExtremeXOS 12.0.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the Switch Engine v33.2.1 Licensing Guide document.
