configure pim crp timer
configure pim {ipv4 | ipv6} crp timer crp_adv_interval
Description
Configures the candidate rendezvous point advertising interval in PIM sparse mode operation.
Syntax Description
ipv4 Specifies an IPv4 address.
ipv6 Specifies an IPv6 address.
crp_adv_interval Specifies a candidate rendezvous point advertising interval in seconds. The range is 1 to 1,717,986,918.
Default
The default is 60 seconds.
Usage Guidelines
Increasing this time results in increased convergence time for CRP information to the PIM routers.
The following example configures the candidate rendezvous point advertising interval to 120 seconds:
configure pim crp timer 120
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.2.1 Licensing Guide document.
