disable ospf export
disable ospf export [bgp | direct | direct-inter-vr | host-mobility |e-bgp | i-bgp | rip | static | isis | isis-level-1| isis-level-1-external | isis-level-2 | isis-level-2-external]
Description
Disables redistribution of routes to OSPF.
Syntax Description
bgp Specifies BGP routes.
direct Specifies direct routes.
Specifies Inter-VR leaked direct routes. Specifies Inter-VR leaked direct routes.
host-mobility Specifies host mobility.
e-bgp Specifies E-BGP routes.
i-bgp Specifies I-BGP routes.
rip Specifies RIP routes.
static Specifies static routes.
isis Specifies IS-IS routes.
isis-level-1 Specifies ISIS Level 1 routes.
isis-level-1-external Specifies ISIS Level 1 External routes.
isis-level-2 Specifies ISIS Level 2 routes.
isis-level-2-external Specifies ISIS Level 2 External routes.
Default
The default setting is disabled.
Usage Guidelines
Use this command to stop OSPF from exporting routes derived from other protocols.
The following command disables OSPF to export BGP-related routes to other OSPF routers:
disable ospf export bgp
Platform Availability
