Configures the global PIM timers on the specified router interfaces.
| ipv4 | Specifies the IPv4 address family. |
| timer | Specifies to configure the timer. |
| hello_interval | Specifies the amount of time before a hello message is sent out by the PIM router. The range is 1–65,535 seconds. |
| jp_interval | Specifies the join/prune interval. The range is 1–65,535 seconds. |
| tunnel | Specifies the tunnel name. |
| tunnel_name | Specifies the name of the PIM interface. |
| all | Specifies to apply to all interfaces. |
These default timers should only be adjusted when excess PIM control packets are observed on the interface.
The following example configures the PIM timers on the tunnel accounting:
configure pim timer 150 300 tunnel accounting
This command was first available in ExtremeXOS 32.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.2.1 Licensing Guide document.
