Displays the secure socket layer (SSL) configuration.
| manufacturing | Shows manufacturer-installed certificates. |
| trusted-ca | Shows trusted CA certificates. |
| ocsp-signature-ca | Shows OCSP signature CA certificates. |
| file_name | Prints specified certificate file. |
| all | Prints all certificates. |
| certificate | Prints the certificate. |
| ssh | Specifies to print the SSH server certificate. |
| detail | Displays detailed SSL information. |
N/A.
The show ssl command displays the SSL configuration. The following is sample output from this command:
HTTPS Port Number: 443 Private Key matches with the Public Key in certificate. (or Private key does not match with the Public Key in the certificate) RSA Key Length: 1024 Certificate: Data: Version: 1 (0x0) Serial Number: 6 (0x6) Signature Algorithm: md5WithRSAEncryption Issuer: C=AU, O=CryptSoft Pty Ltd, CN=Test CA (1024 bit) Validity Not Before: Oct 16 22:31:03 2000 GMT Not After : Jan 14 22:31:03 2003 GMT Subject: C=AU, O=CryptSoft Pty Ltd, CN=Server test cert (512 bit) Manufacturing certificate: Not present
This command was first available in the ExtremeXOS 11.2.
The trusted-ca and ocsp-signature-ca options were added in ExtremeXOS 22.1.
