show auto-peering
show auto-peering {bgp | ospf}
Description
This command displays the status of BGP or OSPF auto-peering and the learned auto-peering interfaces and corresponding remote peer information.
Syntax Description
ospf Shows OSPF auto-peering status and interface information.
bgp Shows BGP auto-peering status and interface information.
Default
N/A
Usage Guidelines
All existing BGP show commands can be used to display the status of BGP peers and routes.
The following example shows the status of BGP auto-peering:
# show auto-peering bgp
Type     : BGP
Password :
Router ID: 2.2.2.102
AS       : 102
Peer Id     Password
2222        None
2223        #$75Zvb3YfCBE/4+eSQE5dA5T2lmhF5A==
VLAN          Neighbor IP Address      Router ID       Remote AS  Port    Fabric ID  Peer
SYS_BGP_0002  fe80::204:96ff:fe9d:66e8 3.3.3.103       103        69      0          Yes
The following example shows OSPF auto-peering information:
# show auto-peering ospf
Type     : OSPF
Router ID: 1.1.1.54
VLAN          Router ID       Port    Fabric ID  Peer
SYS_OSPF_0002 1.1.1.55        19      0          No
This command was first available in ExtremeXOS 22.5.
Peer ID and password information was added in ExtremeXOS 30.5.
The ospf option was added in ExtremeXOS 30.6.
Platform Availability
This feature requires the Advanced Edge license. For more information about licenses, see the Switch Engine v33.2.1 Licensing Guide .
