clear counters vrrp
clear counters vrrp {{vlan vlan_name} {vrid vridval}}
Description
Clears, resets all VRRP statistics and counters.
Syntax Description
vlan_name Specifies the name of a VRRP VLAN.
vridval Specifies the VRRP Router ID (VRID) for a VRRP instance. To display the configured VRRP router instances, enter the show vrrp command.
Default
N/A.
Usage Guidelines
Use this command to reset the VRRP statistics on the switch. Statistics are not reset when you disable and re-enable VRRP.
If you do not enter a parameter, statistics for all VRRP VLANs are cleared.
If you specify only VLAN name, statistics for all VRRP VRIDs on that VLAN are cleared.
If you specify VLAN name and VRRP VRID, only statistics for that particular VRID are cleared.
The following command clears the VRRP statistics on VRRP VLAN v1:
clear counters vrrp vlan v1
The following command clears the VRRP statistics for VRID 1 on VRRP VLAN v1:
clear counters vrrp vlan v1 vrid 1
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature,see the Switch Engine v33.2.1 Licensing Guide document.
