show bgp evpn l3vni
show bgp evpn l3vni {vr vr_name}}
Description
Shows the L3 VNI entries from the EVPN MAC/IP table.
Syntax Description
bgp Specifies showing the BGP configuration.
evpn Specifies showing the EVPN configuration.
l3vni Specifies showing the integrated routing and bridging IP VRF VNI configuration.
vr Specifies showing the VRF.
vr_name Provides the VRF name.
Default
N/A.
Usage Guidelines
If you do not specify a VR, all VRs appear.
The following example shows all L3 VNI entries:
1 # show bgp evpn l3vni
VRF Name                         Layer 3 VNI  RD
vr-a                             10300        2.2.2.2:10300
vr-b                             10100        2.2.2.2:10100
vr-c                             10200        2.2.2.2:10200
The following example shows L3 VNI entries for VR "vr-b":
# show bgp evpn l3vni vr vr-b
This command was first available in ExtremeXOS 30.6.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.2.1 Licensing Guide document.
