delete vrrp vlan vrid
delete vrrp vlan vlan_name vrid vridval
Description
Deletes a specified VRRP instance.
Syntax Description
vlan_name
Specifies the name of a VRRP VLAN.
vridval
Specifies the VRID for the VRRP instance. To display the configured VRRP router instances, enter the show vrrp command.
Default
N/A.
Usage Guidelines
None.
The following command deletes the VRRP instance on the VLAN vrrp-1 identified by VRID 2:
delete vrrp vlan vrrp-1 vrid 2
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.2.1 Licensing Guide document.
