disable ipforwarding ipv6
disable ipforwarding ipv6 [ {vlan} vlan_name | vlan vlan_list] | tunnel tunnel_name | vr vr_name}
Description
Disables routing for one or all interfaces. If no argument is provided, disables routing for all interfaces on the current VR or VRF.
Syntax Description
vlan_name Specifies an IPv6 configured VLAN.
vlan_list Specifies a VLAN list of IDs.
tunnel_name Specifies an IPv6 tunnel.
vr_name Specifies a VR or VRF.
Default
Disabled.
Usage Guidelines
When new IPv6 interfaces are added, IPv6 forwarding is disabled by default.
The following example disables forwarding of IPv6 traffic for a VLAN "accounting":
disable ipforwarding ipv6 vlan accounting
Platform Availability
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.2.1 Licensing Guide document.
