Disables the specified UPM log target.
| upm_profile_name | Specifies the name of the UPM log target to be disabled. |
N/A.
This command disables the log target and retains any configurations applied to that target. To delete a target and any configuration applied to the target, use the following command:
delete log target upm {upm_profile_name}The following example disables the UPM log target "testprofile1":
disable log target upm testprofile1
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.2.1 Licensing Guide document.
