show pim anycast-rp
show pim {ipv4 | ipv6} anycast-rp {ip_address}
Description
Shows rendezvous point (RP) for Anycast RP using PIM (RFC 4610) information.
Syntax Description
ipv4 Specifies IPv4 address family.
ipv6 Specifies IPv6 address family.
anycast-rp Shows Anycast RP information.
ip_address Shows information for a specific Anycast RP.
Default
N/A.
Usage Guidelines
The Anycast RP using PIM feature provides fast convergence when RP routers fail using PIM protocol without using the source discovery protocol Multicast Source Discovery Protocol (MSDP) for both IPv4 and IPv6 address families.
To configure or remove RPs, use the configure pim {ipv4 | ipv6} anycast-rp ip_address [policy | none] command.
The following example shows information for all Anycast RP:
# show pim anycast-rp
Anycast RP        Policy
                    Peer's Address      Reg/Stop In    Reg/Stop Out
150.150.150.1     pim-domain1-v4-anycast-rp
                    10.10.10.1*                   50              50
                    20.20.20.1                    45              100
                    30.30.30.1                    45              56
100.100.100.1     pim-domain1-v4-anycast-rp
                    10.10.10.1*                   0               0
                    20.20.20.1                    0               0
                    30.30.30.1                    0               0
Total number of anycast RP: 2
* Indicates local address
The following example shows information for all Anycast RP at IPv6 addresses:
# show pim ipv6 anycast-rp
Anycast RP                                   Policy
2002:db8:85a3::8a2e:370:7334                 pim-domain1-v6-anycast-rp
    2001:db8:85a3::8a2e:370:7334*                         50             50
    2001:db8:85a3::8a2e:370:7335                          45             100
    2001:db8:85a3::8a2e:370:7336                          45             56
    2001:db8:85a3::8a2e:370:7337                          45             56
3002:db8:85a3::8a2e:370:7334                 pim-domain2-v6-anycast-rp
    3001:db8:85a3::8a2e:370:7334*                         50             50
    3001:db8:85a3::8a2e:370:7335                          45             100
    3001:db8:85a3::8a2e:370:7336                          45             56
The following example shows information for the Anycast RP at IPv6 address 2001:0db8:85a3:0000:0000:8a2e:0370:7334:
# show pim ipv6 anycast-rp 2002:0db8:85a3:0000:0000:8a2e:0370:7334
Anycast RP                                   Policy
This command was first available in ExtremeXOS 31.1.
Platform Availability
This command is available on platforms that support the appropriate license for the PIM feature. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.2.1 Licensing Guide .
