Unconfigures all the router-discovery parameters and resets them to their respective default values.
| vlan_name | Specifies an IPv6 configured VLAN. |
N/A.
Each of the router-discovery parameters is set to the default value. For example, the default-lifetime parameter is set to 1800 seconds. The default value for each of the router-discovery parameters is listed in the corresponding configure vlan router-discovery command description.
The following example unconfigures all the router-discovery parameters for the VLAN top_floor:
unconfigure vlan top_floor router-discovery
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.2.1 Licensing Guide document.
