show pim snooping
show pim snooping {vlan} vlan_name
Description
Displays the PIM snooping configuration for a VLAN.
Syntax Description
vlan_name Specifies a VLAN.
Default
Disabled.
Usage Guidelines
None.
The following command displays the PIM snooping configuration for the default VLAN:
* sw1.79 # show pim snooping  "Default"
PIM Snooping               ENABLED
Vlan Default(1)            Snooping DISABLED
The following command displays global PIM Snooping configuration:
* (pacman debug) sw1.81 # show pim snooping
PIM Snooping         Enabled
<S,G,RPT> Prune      Accept
Vlan             PIM Snooping     DR               #Nbr
l18              Enabled          NO DR            0
<S,G,RPT> Prune option was added in ExtremeXOS 15.7.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.2.1 Licensing Guide document.
