configure qosprofile weight
configure qosprofile qp8 weight weight_value
Description
This command enables the user to input a weight value for queue service weighting in the weighted-round-robin scheduler or weighted-deficit-round-robin scheduler for this QoS profile. The weight value of both WRR and WDRR algorithms have been extended to 1-127 on this supported hardware (refer to the Switch Engine v33.2.1 User Guide for supported hardware).
Syntax Description
weight_value Range is 1-15 or 1-127 depending on hardware type.
Default
Strict priority.
Usage Guidelines
Use this command to input a weight value for queue service weighting in the weighted-round-robin scheduler or weighted-deficit-round-robin scheduler for this QoS profile. The weight value of both WRR and WDRR algorithms have been extended to 1-127 on this supported hardware (refer to the ExtremeXOS 22.6 User Guide for supported hardware).
Example output not yet available and will be provided in a future release.
This command was first available in ExtremeXOS 12.7.
Platform Availability
