Shows the interfaces of a running guest virtual machine (VM).
| vm | Designates a virtual machine. |
| vm_name | Specifies the VM name to show interfaces for. |
| guest | Specifies guest OS viewpoint. |
| interfaces | Specifies interfaces and addresses. |
N/A.
The Integrated Application Hosting (IAH) feature requires the Solid State Storage Device SSD-120.
For this command to work, qemu guest agent must be running on the guest VM.
The following example shows the interfaces for VM "vm1":
# show vm vm1 guest interfaces Name MAC address Protocol Address ------------------------------------------------------------------------------- lo 00:00:00:00:00:00 ipv4 127.0.0.1/8 - - ipv6 ::1/128 ens8 52:54:00:d4:88:59 ipv4 10.68.13.7/24 - - ipv6 fe80::5054:ff:fed4:8859/64 ens6 00:11:88:fe:ab:75 ipv4 192.168.1.5/24 - - ipv6 fe80::211:88ff:fefe:ab75/64 ens7 00:11:88:fe:ab:76 ipv4 192.168.0.5/24 - - ipv6 fe80::211:88ff:fefe:ab76/64
This command was first available in ExtremeXOS 30.3.
This command is available on all platforms that support the Integrated Application Hosting (IAH) feature and have a Core or Premier license installed. For a list of platforms that support the IAH feature and for information about licenses, see the Switch Engine v33.2.1 Licensing Guide .
