unconfigure ripng
unconfigure ripng {vlan vlan-name | tunnel tunnel-name | vlan all | tunnel all}
Description
Resets RIPng parameters to the default value.
Syntax Description
vlan-name Specifies an IPv6 configured VLAN.
tunnel-name Specifies an IPv6 tunnel.
all Specifies either all IPv6 configured VLANs or all IPv6 tunnels.
Default
N/A.
Usage Guidelines
Issuing the command unconfigure ripng resets all the interfaces and the global configuration to the defaults, and disables RIPng, as that is the default.
The following command resets the RIPng configuration to the default for the VLAN finance:
unconfigure rip finance
Platform Availability
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.2.1 Licensing Guide document.
