Displays the multicast cache entries created by PIM.
| ipv4 | Displays IPv4 PIM information |
| ipv6 | Displays IPv6 PIM information. |
| detail | Specifies to display the information in detailed format. |
| group_addr | Specifies an IP group address. |
| source_addr | Specifies an IP source address. |
| state-refresh | Specifies to display the PIM cache entries with state refresh parameters. |
| mlag-peer-info | Shows This command is available on all Universal switches supported in this document. peer related information. |
N/A.
Displays the following information:
When the detail option is specified, the switch displays the egress VLAN list and the pruned VLAN list.
The following command displays the PIM cache entry for group 239.255.255.1:
Switch.33 # show pim cache 239.255.255.1 Index Dest Group Source InVlan Origin [0000] 239.255.255.1 124.124.124.124 (WR) v4 Sparse Entry timer is not run; UpstNbr: 200.124.124.24 EgressIfList = vbs15(0)(FW)(SM)(I) [0001] 239.255.255.1 118.5.1.1 (S) vbs5 Sparse Expires after 186 secs UpstNbr: 0.0.0.0 RP: 124.124.124.124 via 200.124.124.24 in v4 EgressIfList = vbs15(0)(FW)(SM)(I) , vpim5(170)(FW)(SM)(S) PrunedIfList = v4(0)(SM) Number of multicast cache = 20 Entry flags :- R: RP tree. S: Source tree. W: Any source. Egress/Pruned interface flags :- SM: Sparse Mode DM: Dense Mode Fw: Forwarding PP: Prune pending AL: Assert Loser N: Neighbor present I: IGMP member present S: (s,g) join received Z: (*,g) join received Y: (*,*,rp) join received
The following command displays the PIM-DM cache entry with state-refresh information for group 225.0.0.1:
Switch.5 # show pim cache state-refresh 225.0.0.1 Index Dest Group Source InVlan Origin [0001] 225.0.0.1 64.1.1.100 (S) vixia Dense Not Pruned Expires after 204 secs UpstNbr: 0.0.0.0 Refresh State: Originator(20), TTL: 16 EgressIfList = v36(0)(FW)(DM)(N) [0001] 225.0.0.1 65.1.1.100 (S) vixia Dense Not Pruned Expires after 195 secs UpstNbr: 65.1.1.200 Refresh State: Not-Originator(25), TTL: 8 EgressIfList = v36(0)(FW)(DM)(N)
The following command displays the ingress VLAN information of all MLAG peers:
* (pacman debug) sw6.2 # show pim c mlag-peer-info
[0000] 226.1.1.1 61.2.2.2 (WR) fifthteen Sparse
Entry timer is not run; UpstNbr: 51.15.15.2
Peer Ingress VLAN (ISC 1): 51.15.15.4/24 (Same)
EgressIfList = eight(0)(FW)(SM)(I) , five(0)(FW)(SM)(I) , ten(0)(FW)(SM)(I)
[0001] 226.1.1.1 112.2.2.202 (S) fifthteen Sparse
Expires after 203 secs UpstNbr: 51.15.15.2
RP: 61.2.2.2 via 51.15.15.2 in fifthteen
PrunedIfList = ten(0)(SM)(AL)
This command was modified in ExtremeXOS 15.2 to display MLAG peer information.
The ipv4 and ipv6 keyword options were added in ExtreameXOS 15.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.2.1 Licensing Guide document.
