enable pim
enable pim {ipv4 | ipv6}
Syntax Description
ipv4 Specifies the IPv4 address family.
ipv6 Specifies the IPv6 address family.
Syntax Description
Default
Disabled.
Usage Guidelines
None.
The following command enables PIM on the system:
enable pim
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.2.1 Licensing Guide document.
