show ip nat rule
show ip nat rule {detail}
Description
Displays information about IP Network Address Translation (NAT) rules.
Syntax Description
ip Specifies Internet Protocol (IP).
nat Specifies NAT.
rule Specifies viewing NAT rule information.
detail Specififes showing detailed NAT rule information.
Default
N/A.
Usage Guidelines
The following example shows basic information about all IP NAT rules configured on the switch:
# show ip nat rule
Rule Name                         State     VR                  IPAddr              NewIPAddr
                                    Type      EgressVLAN           Protocol  L4Port   NewL4Port
baseNapt                          Enabled   VR-Default          10.1.1.100/24       112.123.234.200
                                    NAPT      out                  ---       -----    -----
srcTxlate                         Enabled   VR-Default          10.20.30.40/32      50.1.1.100
                                    Src-NAT   out                  ---       -----    -----
natIncomplete                     Disabled  -----               -----               -----
                                    Src-NAT   -----                ---       -----    -----
dnat-http-server                  Enabled   VR-Default          40.1.1.2/32         10.1.1.100
                                    Dst-NAPT  out                  UDP       8080     80
NAT                                      : Enabled
Total number of NAT rules                : 4
Total number of source NAT rules         : 2
Total number of destination NAPT rules   : 1
Total number of configured NAPT rules    : 1
Total number of dynamic NAPT rules       : 0
Maximum number of NAT rules              : 1024
Aging Time                               : 10 minutes
The following example shows detailed information about all IP NAT rules configured on the switch:
show ip nat rule detail
Rule Name                : baseNapt
Type                     : NAPT
Admin State              : Enabled
VR Name                  : VR-Default
New VR Name              : VR-Default
Egress VLAN Name         : out
Source IP Address        : 10.1.1.100
Source IP Mask           : 255.255.255.0
New Source IP Address    : 112.123.234.200
Statistics Monitor       : Off
Rule Name                : srcTxlate
Type                     : Src-NAT
Source IP Address        : 10.20.30.40
Source IP Mask           : 255.255.255.255
New Source IP Address    : 50.1.1.100
Rule Name                : natIncomplete
Type                     : Src-NAT
Admin State              : Disabled
VR Name                  :
New VR Name              :
Egress VLAN Name         :
Source IP Address        :
Source IP Mask           :
Rule Name                : dnat-http-server
Type                     : Dst-NAPT
Dest IP Address          : 40.1.1.2
Dest IP Mask             : 255.255.255.255
New Dest IP Address      : 10.1.1.100
Protocol                 : UDP (17)
Dest Port                : 8080
New Dest Port            : 80
NAT                                      : Enabled
Aging Time                               : 20 minutes
This command was first available in ExtremeXOS 31.2.
Platform Availability
This command is available on the switches that support the IP NAT feature. For information about which switches support this and other features, see the Switch Engine v33.2.1 Licensing Guide document.
