show cfm
show cfm { domain_name { association_name {{ports port_list {[intermediate-point | [end-point [up|down]]]}}}
Description
Displays the current CFM configuration on the switch.
Syntax Description
domain_name Enter the name of the domain you want to display.
association_name IEEE 802.1ag or ITU-T Y.1731 association name.
port_list Enter the ports in the domain and association you want to display.
up Enter this to display the UP MEP for the specified MA.
down Enter this to display the DOWN MEP for the specified MA.
intermediate-point Enter this to display the MIPs for the specified MA.
Default
N/A.
Usage Guidelines
This command displays the following information:
  • Domain names
  • MA levels
  • Association names
  • VLAN names
  • Transmit Interval
  • UP MEPs
  • MEPIDs
  • MEP transmit intervals
  • MEP State
  • DOWN MEPs
  • Intermediate points (MIPs)
  • Total number of CFM ports on the switch
  • Destination MAC Type
  • VPLS-based MPs
  • Sender ID information
  • ISID Intermediate Point
For the number of domains, ports, MEPs, MIPs, and associations supported on the switch, see the Supported Instances for CFM section in the Switch Engine v33.2.1 User Guide .
The show cfm command displays the current CFM configuration on the switch:
* switch # show cfm
Domain: "dnsname", MD Level: 2
    Association: "10", Destination MAC Type: Multicast, VLAN "v1" with 2 cfm ports
    Transmit Interval: 1000 ms,  Type : IEEE 802.1ag Maintenance Association
        port 1; Up End Point,   mepid: 100, transmit-interval: 1000 ms (from association)
                MEP State: Enabled, CCM Message: Enabled, Send SenderId TLV: Disabled
                Faulting State               : No
                Last Faulting State Change   : Wed Jun 19 09:12:13 2013
                MEP Error Defects            : None
                Port Status                  : Up
          port 15; Intermediate Point ( Dynamic )
        Association: "VSNLMEG1", Destination MAC Type: Multicast, VLAN "none" with 0 cfm ports
        Transmit Interval: 1000 ms,  Type : ITU-T Y.1731 Maintenance Entity Group
        Association: "snmp_ma_name", Destination MAC Type: Multicast, VLAN "none" with 0 cfm ports
    Domain: "dom1", MD Level: 5
        Association: "VSNLMEG1", Destination MAC Type: Multicast, VLAN "v2" with 2 cfm ports
        Transmit Interval: 10 ms,  Type : ITU-T Y.1731 Maintenance Entity Group
          port 1; Down End Point, mepid: 100, transmit-interval: 3.3 ms (configured)
                Faulting State               : Yes
                Last Faulting State Change   : Wed Jun 19 09:08:12 2013
                MEP Error Defects            : Remote
                Port Status                  : Up
          port 15; Down End Point, mepid: 200, transmit-interval: 10 ms (from association)
                Last Faulting State Change   : Wed Jun 19 09:08:13 2013
                Port Status                  : Up
         Association: "short_ma_name", Destination MAC Type: Multicast, VLAN "v1" with 2 cfm ports
                Last Faulting State Change   : Wed Jun 19 09:09:47 2013
                Port Status                  : Up
           port 15; Down End Point, mepid: 200, transmit-interval: 1000 ms (from association)
                MEP Error Defects            : RDI, Remote
                Port Status                  : Up
    Domain: "dom2", MD Level:  6
          Association: "VSNLMEG1", Destination MAC Type: Unicast, VLAN "v2" with 2 cfm ports
                Faulting State               : No
                Last Faulting State Change   : Wed Jun 19 09:39:14 2013
                Port Status                  : Up
          port 15; Intermediate Point ( Dynamic )Domain: "00:11:22:33:44:55.6666", MD Level: 7
          Association: "VSNLMEG1", Destination MAC Type: Multicast, VLAN "v3" with 2 cfm ports
                Faulting State               : No
                Last Faulting State Change   : Wed Jun 19 09:10:10 2013
                Port Status                  : Up
          Association: "short_ma_name", Destination MAC Type: Multicast, VLAN "v4" with 2 cfm ports
          Enabled IPaddress:
        10.10.10.1
                Faulting State               : No
                Last Faulting State Change   : Wed Jun 19 09:15:08 2013
                Port Status                  : Up
Total Number of Domain             : 4
Total Number of Association        : 8
Total Number of Up MEP             : 4
Total Number of Down MEP           : 4
Total Number of MIP                : 4
Total Number of CFM port           : 12
Total Number of SW MEP             : 4
Total Number of HW MEP              : 4
Total Number of VPLS MIP(Static/Up): 0 / 0
MEP Error Defect Types:
          Remote : Not receiving CCMs from Remote MEP
          Error  : Erroneous CCM received
          XCON   : Cross-connect CCM received
          RDI    : Remote Defect Indication sent by some MEP
This command was first available in ExtremeXOS 11.4.
Transmit Interval and MEP State were added in ExtremeXOS 12.3.
Platform Availability
