unconfigure mld ssm-map
unconfigure mld ssm-map {{vr}vr_name }
Description
Deletes all MLD SSM Mapping entries on a VR.
Syntax Description
vr vr_name Specifies the virtual router name.
Default
Disabled.
Usage Guidelines
Use this command to delete all MLD SSM Mapping entries on a specified VR.
The following command deletes MLD SSM mapping on VR1 :
unconfigure mld ssm-map vr vr1
This command was first available in ExtremeXOS 15.5.
Platform Availability
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.2.1 Licensing Guide document.
