Displays MPLS configuration information.
N/A.
The following command displays the MPLS configuration parameters for the switch:
# show mpls MPLS System MPLS System : User VR (Green) MPLS Admin Status : Enabled MPLS Oper Status : Enabled RSVP-TE Admin Status : Enabled RSVP-TE Oper Status : Enabled LDP Admin Status : Enabled LDP Oper Status : Enabled SNMP Traps : Disabled L2VPN SNMP Traps : Enabled EXP Examination : Disabled EXP Replacement : Disabled LSR ID : 11.100.100.20
This command was first available in ExtremeXOS 11.6
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.2.1 Licensing Guide document.
