unconfigure stacking license-level
unconfigure stacking {node-address node_address | slot slot_number} license-level
Description
This command removes a previously configured license level restriction.
Syntax Description
node_address Specifies the MAC address of a node in the stack. To view the MAC addresses for all nodes in a stack, enter the show stacking command.
slot_number Specifies the slot number of the target node. To view the slot numbers, enter the show stacking command.
Default
N/A.
Usage Guidelines
If no node is specified, the licensing restriction is removed from all nodes in the stack topology.
After the command is executed, the following message appears:
This command will take effect at the next reboot of the specified node(s).
To unconfigure the stacking license level on a node:
unconfigure stacking node-address 00:04:96:26:6b:ed license-level
To unconfigure the stacking license level configured on slot 4:
unconfigure stacking slot 4 license-level
This command was first available in ExtremeXOS 12.0.
Platform Availability
This command is available with all licenses and platforms that support the SummitStack feature. For information about which licenses and platforms support the SummitStack feature, see the Switch Engine v33.2.1 Licensing Guide document.
