delete mpls static lsp
delete mpls static lsp [lsp_name | all]
Description
Deletes internal resources for one or all static LSPs.
Syntax Description
lsp_name Identifies the LSP to be deleted.
all Specifies that all LSPs are to be deleted.
Default
N/A.
Usage Guidelines
All resources associated with the specified LSPs are released. Static LSPs cannot be deleted when the LSP is configured for an IP route or VPLS configuration.
The following command deletes a static LSP:
delete mpls static lsp lsp598
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.2.1 Licensing Guide document.
