CLI File Name Completion
When entering a command, at the point where a file name could be entered, press [Tab] or ? to display an alphabetically sorted list of possible file names. You can also type part of the file name to display a filtered list of file names matching what you have typed so far.
The following commands support this behavior:
cd directory_name configure access-list aclname [any | ports
port_list | vlan
vlan_name ] {ingress } configure ip-security dhcp-bindings storage filename name
configure snmp access-profile [ access_profile {readonly | readwrite } | [[add rule ] [first | [[before | after ] previous_rule ]]] | delete rule | none ]
configure ssh2 access-profile [ access_profile | [[add
rule | none ] configure telnet access-profile [ access_profile | [[add rule ] [first | [[before | after ] previous_rule ]]] | delete rule | none ]
configure vlan vlan_name udp-profile [profilename | none ]
cp old_name
new_name create process name executable exe {start [auto | on-demand ]} {node
node } {vr
vr-name } {description
description } {arg1 {arg2 { arg3 { arg4 {
arg5 { arg6 { arg7 { arg8 { arg9
}}}}}}}}} create process name
python-module
python-module {start [auto | on-demand ]} {node
node } {vr
description } {arg1 {arg2 {arg3 {arg4 {arg5 {arg6 {arg7 {arg8 {arg9 }}}}}}}}} edit policy filename
enable license file filename
enable ssh2 {access-profile [access_profile | none ]} {port tcp_port_number } {vr [vr_name | all | default ]}
load script filename {arg1 } {arg2 } ... {arg9 }
ls file_name
mkdir directory_name mv old_name
new_name scp2 {cipher
cipher } {mac
mac } {compression [on | off ]} {port
portnum } {vr
vr_name } user [hostname | ipaddress ]:remote_file
local_file
show ssl {[trusted-ca | ocsp-signature-ca ] [file_name | all ]} {manufacturing }{certificate {ssh } | detail } TFTP tftp get [ ip-address | host-name ] { vr
vr_name } { block-size
block_size } remote-file
local-file } {force-overwrite } tftp put [ ip-address | host-name ] {vr
vr_name } {block-size
block_size }local-file { remote-file }
rm file_name
rmdir directory_name run script filename {arg1 } {arg2 } ... {arg9 } unconfigure ssl certificate
all ]
