disable mld-ssm map
disable mld-ssm map {{vr} vr_name}
Description
Disables MLD SSM mapping on a VR.
Syntax Description
vr vr_name Specifies a virtual router name.
Default
Disabled.
Usage Guidelines
Use this command to disable MLD SSM mapping on a VR.
The following example disables SSM mapping on VR1:
disable mld-ssm map vr vr1
This command was first available in ExtremeXOS 15.5.
Platform Availability
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.2.1 Licensing Guide document.
