Deletes the specified VLAN from the specified PVLAN.
| name | Specifies the name of the PVLAN from which the VLAN is deleted. |
| network | Specifies that the VLAN to be deleted is a network VLAN. |
| subscriber | Specifies that the VLAN to be deleted is a subscriber VLAN. |
| vlan_name | Specifies the VLAN to delete from the PVLAN. |
N/A.
This command deletes a VLAN from a PVLAN, but it does not delete the VLAN from the system—it just breaks the link between the VLAN and the PVLAN. You can use this command to delete both network and subscriber VLANs.
The following example deletes network VLAN "sharednet "from the PVLAN named "companyx":
configure private-vlan companyx delete network sharednet
This command is available on all platforms that support the Private VLAN feature. For features and the platforms that support them, see the Switch Engine v33.2.1 Licensing Guide document.
