disable ipmcforwarding
disable ipmcforwarding {vlan name}
Description
Disables IP multicast forwarding on a router interface.
Syntax Description
name Specifies a VLAN name.
Default
Disabled.
Usage Guidelines
If no options are specified, all configured IP interfaces are affected. When new IP interfaces are added, IP multicast forwarding is disabled by default.
IP forwarding must be enabled before enabling IP multicast forwarding.
Disabling IP multicast forwarding disables any Layer 3 multicast routing for the streams coming to the interface.
The following example disables IP multicast forwarding on the VLAN accounting:
disable ipmcforwarding vlan accounting
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.2.1 Licensing Guide document.
