disable ripng
disable ripng
Description
Disables RIPng for the whole router.
Syntax Description
Default
Disabled.
Usage Guidelines
None.
The following command disables RIPng for the whole router:
disable ripng
Platform Availability
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.2.1 Licensing Guide document.
